OP-51 Practice Kit
Wrench
Member
Working through my first practice kit. Referencing the attached completed kit picture I found on the forum, as well as the print supplied with my kit.
The print references 5 An426D3-3.5 rivets, which I noted on the print, but the actual completed piece has 6. In addition, the one hole I circled is bigger than the others for some reason.
My first shot at this so I want to be sure I am understanding what I'm looking at.... basically a sanity check.
Thanks !
Note: Additional picture added to better describe the concern. I should have done this on my initial posting..
Practice
They are telling you there are 5 rivets that size. Apparently the others are a different size.
Wrench
You have the "5 rivets labeled wrong.
The 5 they are referring to are the ones on the rectangular piece and the two peninsulas. Total of 5.
Then the other note to the right indicates 4 rivets total in the two ovals.
Below you have the 6 LP4 rivets.
Looks like nothing goes in the larger hole your question mark is next to.
Have fun
Arnie
