N546RV
Today's first order of business was to taper the HS-810 and HS-814 reinforcements. I had previously laid out my pattern for the taper, but wasn't quite sure how to attack the metalwork. After taking a look at the build logs for a couple locals, decided that the best way to proceed was to go get myself a belt sander and have at it. That purchase was made Friday afternoon, but it wasn't until today that I was able to give it a whirl.
(I know a band saw would make quick work of this, but I don't have one, and I wasn't prepared to invest in one quite yet)
It quickly became evident that the belt sander route wasn't working all that great. Maybe my expectations for the speed of material removal were too high, but it seemed to be going really, really slow. And that was on HS-810; HS-814 looked to have a fair bit more material to remove. I tried using a Dremel with the cutoff wheel, but it took about two minutes to conclude that that thing was way too hard to control.
Then I remembered reading of a builder who roughed the cuts with a hacksaw and then refined with the scotch brite wheel. Off to Lowes I went to fetch a hacksaw. Cutting the pieces with that went fairly well, but being something of a perfectionist, I wanted the taper sides to be fairly straight. So I went from the hacksaw to the belt sander, straightened the edges, and rounded the ends. Then it was on the the bench grinder to get rid of the marks from the sander.
Problem was-and I was gradually realizing this during the process, but too late to save anything-all that perfectionism resulted in me removing a lot of material. The end products are pretty ugly, but maybe not horribly so. But my rounded ends went too far. At least one place I ended up with a radius of maybe 3/16.
End result: I'm chalking both those pieces up to a learning experience and reordering come Tuesday. I'm displeased with not only the finished product, but the haphazard way I went about doing the work.
Lessons learned:
End of the day, I guess I'm taking care of the educational aspect of building. Now to go find something else to work on while I wait for my replacement parts to come...and maybe look into investing in a band saw.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Lessons learned:
- Just like we have get-there-itis in the air, I think this was was get-it-done-itis. Because I wanted those tapers done, once my plan A failed, I started cooking up alternatives on the fly without really thinking them through. Then, rather than realizing I was getting in a hurry and slowing down, I plowed ahead.
- Relevant to plan A failing: Don't practice on real plane parts.
- After seeing the results of my work, then I came inside and poked around here at VAF. Whereupon I realized that maybe I was focusing on the wrong things here. I sketched out my cut lines from the plans, and at that point my allegiance was to those lines, rather than to the reason for those lines. Had I thought it through, I would have realized that not removing too much material was more important than making a perfectly round radius, or perfectly straight tapers.
