Funguy
Hi All - I'm investigating purchasing a WW G200L Propeller from a Van's Airforce vendor and noticed that my existing flywheel setup does not look like any contemporary flywheels. This is on a O-320-E3D. It turns out that it has 7/16" flange bolts at the propeller rather than the expected 3/8" bolts and a further look at the flywheel and spacer setup makes me suspect that the 3/8" bolts are holding the flywheel and the double stack of spacers eventually ends up with 7/16" bolts. I am hoping that this is an older setup that's still useable. However, if someone has seen this style before and can give me some insight into much of a pain this will be changing to a new propeller, I would be grateful.
Cheers, Sean
Cheers, Sean
