RV-3 spinner options
Steve, I recently purchased an RV-3 and have the old style cowling and 12 in fiberglass spinner. The cowling is kind of beat up around the spinner area, and the quality of the 12 in spinner leaves much to be desired. I have a 13 in carbon fiber Whirlwind Aviation spinner that I placed on the removed and attached cowling halves to see how much bigger it was.
The 12 in spinner seems a bit too small for the cowling shape (by about half an inch) and obviously the 13 is too big, but only by about half an inch. I purchased a 13 in Vans spinner off VAF, uncut, and am going to experiment to see if I may cut it down on the back side to custom fit it to my cowl. When I do that I'm sure the two bulkheads will not fit properly, but I'm going to see if either the 12 or 13 in bulkheads can be modified practically to fit before I cut it.
The another alternatives are to purchase the newer 13 in cowl setup, which is expensive and a ton of work. The other thing I'm considering is to build up the nose of the old style cowling with micro balloons to match the 13 in spinner profile. I have searched the internet for other, nicer profiles of light weight composite spinners, but have not found one to my liking as of yet, I dislike the sharp profile of the old style Van's 12 in spinner. I'll look at doing the spinner/cowling mods this winter and post my results on VAF, good or bad.
I did find an option on the Whirlwind Propellor website (Not Whirlwind Aviation), they have a carbon fiber 12 in spinner for their ground adjustable prop, and I asked if they would sell it uncut, I think they said $495 for that, but again, a 12 in spinner is just a bit too small for my 12 in cowling. I didn't like the profile of the 12 in aluminum spinner option I found on ACS either. If you find a better option, please post it here for the group, best regards, Al.
