rvbuilder1
Active Member
I am in the process of replacing a cracked cylinder. Upon removal of the cylinder and oil tubes ( Shroud with push rod inside) I found the shroud half way to failure. The tie wrap holding a rubber hose standoff used to hold # 1 plug wire was fastened to the shroud.
It appears since #1 is up front directly exposed to high wind the hose was working back and forth and abraded the shroud to a .010 groove. In a short time it would have gone completly through the shroud and I would have had oil streaming out.
I was mad when I cracked a cylinder BUT I am now not so mad that I found the groove in the shroud.
I am now replacing ALL rubber hose standoffs with adel clamps. This took place over 2 years and 102 hrs of flight time.
Thought I would pass this along to anyone using tie wraps and rubber hose standoff to be CAREFUL where you put them.
