Oil Tube and Dip Stick
Chuck May
I'm New Here
I need a 12" oil tube and a dip stick for my O320 B2C Lyc. Does anyone have a suggestion? Lycoming wants $350 just for the tube.
Try Bobby
Bobby's Planes 'n parts Ph 94O-682-422O
Weatherford TX. I think You need the long half of the 2 piece tube, cut and calibrate the stick u self
$350 for the tube??? :eek: It's plastic!
I'm pretty sure you could get it from Superior and ECI also. They sell an entire engine, they must sell the parts individually.
cut down oil stick
well when this was overhaul by individual ap mechanic in the end he noted to me that this engine had the long oil tube and stcik he had a pretty new used stick he thru in the short kind but all is well except no marking on stick what the best way you found to mark the stick what did you use to mark it with!!!
