David-aviator
Its that time of the year to remove the oil cooler plate but that also means running with less than desirable oil temperature with this engine unless the OAT is 80. The engine runs cool.
So a 3" butter fly valve was purchased from ACS, a flange, a ratcheting cable and this is the end result.
It works mechanically, will see how oil temp is affected in flight very soon.
