oil temp sensor
Ron B.
Hello all
I have a small brass/copper oil tem sensor that has an end on it that requires a clip to attach the sensor wire to. It's about a 3/16" dia. shaft with a grove machined into at the end where a wire should attach. From my bad description can someone tell me the clip that I need to attach the wire?
Thanks Ron
Gasman, do you mean a spade as in the type that connects to a tongue connector to make a wire connection? I've got lotsa those.
Thanks Ron
