EchoJuliet
Member
Has anyone had success modifying the oil tank vent tube (FF-1218-1) in order to reduce the amount of oil film that accumulates on the aircraft belly? Wondering if changing the tube length (shorter or longer), or a 45 deg. cut on the end the tube would make any difference.. I typically have the oil level at 1/4 to 1/2 on the dipstick flat (warm burp) and am using very little oil - and that small amount is being vented out the tube.
