Just bought the ASA Air-Oil Separator, as I think I'm loosing too much oil from the breather.
Trying to find a spot for the AN4 return line![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't have the plugged port recommended in the instructions on my O320-E2D. The only other port I see plugged is pressurized by the line from the oil cooler.
Any recommendations? Worst case I have a 1/4 aluminum plate covering my vacuum pad I can tap into as a return, but this is a higher than what is recommended in the instructions.
