Nope. Just follow the directions. Mine is probably going on 13 years.So no issues with the aluminum on aluminum and corrosion??
I added a SAF-AIR P5000 to mine about 2 months ago. I believe the threads are aluminum, but don't quote me on that. It felt like aluminum while torqueing it, for what it's worth
I can say that it appears to be of very high quality. I used Loctite 567 (https://www.amazon.com/Loctite-234451-Sealant-degrees-Temperature/dp/B005P3KAUW) on the threads and safety'd it.
Best,
-AJ
RV-6 N642DP
Give Fumoto t202n a look.
Bevan
+1 for the Fumoto. Less expensive, higher quality. Drain outlet size is larger, so it drains quickly.
