Dave Stephens
Active Member
What oil pressure did you guys see on a new IO540 running on straight 80 running in oil?
I'm getting 85psi at 2200 rpm but rises to 90 sometimes setting off the efis alarm, but at take off it goes to 100psi!
Engine has done about 2 hours of running in the plane post lycoming a run in procedure (I need to find the paperwork that come with the engine to see what it did on lycomings test rig)
I want to get a gauge and sender and to fit to verify its not the efis over reading.
As a side note it has a remote oil filter, which I have checked all pipes for kinks etc.
Dave
Dave
