I am doing my final preparation before engine start and I cannot get an indication of any oil pressure. I did the whole oil purging process. 10-15 psi air pressure in the overflow, blocked the ?In? on the oil tank, removed the top spark plugs, filled the oil cooler and lines, and turned prop over 100 times fast, and nothing. No indication of pressure.
Is there a test I can do to check the wiring back to the Skyview? Can I place a small voltage across the two wires to see if the Skyview record a pressure?
