647jc
I plan to install a Vans oil pressure switch IE SPDT PRES-15 SW in addition to the regular oil pressure transducer and fuel pressure transducer (supplied by Dynon) to drive a hobbs meter and a panel idiot light. A typical 0-320 installation has the fuel pressure transducer in the bottom transducer manifold location. The oil pressure transducer in the center location and I ASSUME the oil pressure switch will go in the top location. My question is can I use AN-2D fittings and 1/8? copper tubing (like used in a fuel priming system) off the left side of the manifold to join the middle and top manifold locations to drive the oil pressure switch?
J.C.
J.C.
