I have a hose that connects to an elbow (90 degrees) then in to a manifold which has the oil sensor connected. The manifold end is weeping oil. I'm going to disassemble the connection, clean it and put it back together. My question is how much loctite do you use? just enough to fill the threads? Also, do you put the loctite on both ends of the elbow connection or just the one the connects into the manifold?
TIA!
Clip.
TIA!
Clip.
