plbarrett2004
Active Member
Hello all,
I have an overhauled IO-360 A3B6D. I'm working to plumb fuel and oil lines firewall forward and its all new to me. I have the Lycoming overhaul and parts manual, and the only reference I can find to the oil pressure port is "plug". I'm about 90% sure its this fitting above the oil filter in the photo below. Can someone confirm this is the oil pressure port? Assuming if that is it, that I'll have to remove the current fitting to put the Van's supplied restrictor.
Thanks!
Thanks!
