Please may I give you our symptoms and ask for thoughts?
AFS 3400 indicates an oil pressure and temp in the cruise of 90 psi and 150F in outside temps of 40-70F.
During first take off of the day at 2650 rpm then the pressure always reaches the 115psi limit at oil temps of 90F+.
Should we adjust the oil pressure relief valve or replace the vernatherm or both?
Thanks as always
Sandy
Thanks as always
Sandy
