It just started the other day. 30 minute flight and noticeable oil streak on the belly and around the right rear of the engine. Thought it was the oil filler tube since it was a bit loose. Tightened it up but no luck. Test flight had the same oil streak.
Pulled the top cowl and nothing jumps out as a culprit. Will pull the bottom cowl tomorrow.
Any ideas or recommendations?
Pat
RV7 N931CB KHAF
Pat
RV7 N931CB KHAF
