Mike Buettgenbach
Active Member
I had just finished flying two legs, about 3.5 hours total.
I hadn't inspected the engine compartment for probably 20-25 hours, so I thought it was time to do so (just a good idea, I inspect every 25 hours or so)
What I found was a bit strange: there was a bit of oil on the oil sender hose (I have remote mounted the oil sender) originating just aft of the fuel pump. There was evidence of the oil dripping down on other things, but appeared to originate on that hose (the fire sleeve actually).
No leak or damage in the hose that I could find, and the hose has fire sleeve on it, also in good condition.
Very slight oil coating on the fuel pump. It did not appear to be coming from the pump mounting flange, but rather the crimped flange on the pump. . . . as best I could determine.
Again, the amount of oil was slight, but enough to cause a few drips over the previous 25 hours of flight.
I cleaned all surfaces, reassembled, and will evaluate over the next few hours of flight.
Anybody else seen similar leaks?
I expect I will install the new pump soon, but wanted to post the question for others, and see what evidence might be out there.
It is the original fuel pump, the aircraft has ~250 hrs.
Thx
Thx
