Berchmans
I made the first flight of my RV-8 the other day and noted that the hinge side of the oil door bulges out slightly due to air pressure. I have used the hidden hinge and the standard vans latch fittings without the wing nut ears. Is there a good way to stiffen the door? I have thought about adding a small piece of channel to the underside of the door or possibly installing a couple more of the push and turn fasteners at the hinge corners.
