Barnstormer
Member
Hey out there all you learned ones. I'm curious if anyone has thoughts or if anyone has used remote automotive oil filter setup on O-320.
Pat
Pat
Pat
Testing has shown that the stock screen actually does a pretty good job compared to a paper filter, or Airwolf screens. Money saved on a $20 filter could go towards more frequent oil changes. Also, it's easier to inspect/clean than it is to cut a filter can.
I had a setup almost identical to what Sam used (below) on my old Stinson.
I got the oil from the cooler supply line, and fed the clean oil back into the cooler.
Never had any issues with it in 18 or so years of use.
I did use an aircraft filter on the automotive mount.
