dmaib
I discovered that the Casper Labs 90 degree oil filter adapter will not fit with my B&C SD-20 standby alternator mounted on the vacuum pad. I checked with Casper Labs and they confirmed that this is one combination they cannot make fit.
I would like to install a remote firewall mounted oil filter kit, but would like to know if anyone has one installed with the SD-20 mounted on the vacuum pad and insure that there are no clearance problems.
I will be selling the Casper Labs 90 degree adapter and 1.5 inch spacer. If you are interested, contact me off line
or PM.
or PM.
