Cut one inch out of the center of the tube and bond it back together, using best practices, with glass cloth and epoxy. You can either cut an inch off the bottom of the dip stick or knock out the in the cap, cut an inch off there, redrill and replace the pin.
A bit of sanding, paint and no one will know. You can do this job faster then it would take to send your MC number to a supplier!
