I had the #2 oil drain back tube crack on a recent trip . Was able to trim it back and re -flair the tube and continue on .
Trying to locate the Part Number….its an Angle Valve IO-360 C1A …any help would be appreciated.
DATE RELEASED: June 2010 TITLE: O, LO & TO-360 Parts Catalog DOCUMENT PART NUMBER: PC-306-2 MODELS AFFECTED: O-360-B2A, O-360-C1A, O-360-C1C, O-360-C1E, O-360-C1F, O-360-C2A, O-360-C2C, O-360-C2E, O-360-D2A, O-360-F1A6
That is good pricing compared to other sources. A couple on mine have distorted flares and I will probably replace them and lengthen them slightly to avoid interference with the baffle ties. I will also be replacing the rubber hoses and using constant tension spring clamps while at it.
