plenum
Hi Kent,
I realize the oil fill tube is outside the plenum or baffle seals. If you consider what makes the oil door bulge on the standard set up it is incoming air, not confined to a plenum. In the setup with a plenum, at least some builders are also changing the inlet to the round with ducting to the plenum. Hence my question, has anyone noted a difference in the oil door bulging if a plenum is used? If you look at what Bob Axom is doing, trying to totally isolate the high to low pressure areas with the lower baffles and side baffles, I think one should consider the possibility that some of the oil door bulge may possibly be from lower compartment air (low pressure air) going up the sides as well as air from the standard inlet. I personally would think that with a plenum and ducting there is less chance of oil door bulging, and the low pressure air coming up the sides (if that does happen) would not contribute much too the oil door bulge. A plenum and ducting should minimize oil door bulge due to the very fact that it is outside the high pressure area. Just curious to see if there is a difference.
