using original oil door hardware?
For those flying with the original oil door hardware, are you satisfied? I'm at the point of installing the door in to cowl and I'm debating which way to go. Changes always take time and some are worth it. I think I would like to go with flush mount hardware, but not sure I want to go thru the process. Also wondering if the spring hinge is worth it or not.
