McFly
With the warming temperatures, my oil temperature has skyrocketed. I am showing 210 degrees in cruise when it is only 80 degrees on the ground. I am wondering if it is a problem with the vernatherm since the my oil temp was 160 or so when the surface temperature was in the 50s. My CHTs have always been rock solid at 300-325. I do have a plenum with the cooler mounted behind #4. Ideas?
It may be time to buy a new oil cooler since it looks to have developed a leak (the jury is still out but it looks like it is coming from the cooler and not the fitting). I would like to replace it with a unit that cools better AND has the same footprint. Is there such an animal? Thanks for the help
