skyking902001
Need some advice from the wizards! I have cut the rear baffle for the oil cooler and drilled the 705A for nutplates, etc. The lower inboard nutplate is in contact with a cooling fin. If I insert a bolt and get 1 thread showing, it contacts the cooling fin enough to slightly push the baffle to the rear. My question--is it ok to grind a small relief in the cooling fin? If not, looks like I will need to re-order parts and start again in this area. If I raise the oil cooler enough to clear the fin, I am getting real close to contacting the cowl. Thanks in advance. Baffles--blah!
[/IMG]
![jfgjsj.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi68.tinypic.com%2Fjfgjsj.jpg&hash=a38ac4cda922cb151ac13c2a04987b63)
