I'm at the stage where it's time to mount the oil cooler.
When I trail fit the cooler in the recommended location (mounted on the left rear baffle ) it appears that the rear cylinder will block most of the airflow to the cooler. Is this ok i.e work adequately ?
Or should I be looking at other ways to mount the cooler that will allow more air to flow through the cooler.
![photo-1.jpg](/proxy.php?image=http%3A%2F%2Fi1118.photobucket.com%2Falbums%2Fk610%2FDerek106%2Fphoto-1.jpg&hash=04a8786c3c35300ab1846d5aefd4dff0)
![photo.jpg](/proxy.php?image=http%3A%2F%2Fi1118.photobucket.com%2Falbums%2Fk610%2FDerek106%2Fphoto.jpg&hash=1be4d51b03ece295cc1fb54b56ad92e5)
