wrongway john
Oil Cooler & Pressure Issues
I bought this plane up north last year and really have been pleasantly suprised with it, but the TX heat issues are something I'd like to address. My oil temps are generally in the upper 180?s to lower 190?s in the summer , and I would like to get it into the 160?s if at all possible, to also help with better oil pressure as well. FWIW, I?ve got good compressions and low oil burn, perhaps one quart every 16-22hours, and CHT's are generally in the 330's-340's at cruise, so no problem there or even in climb out.
Looking at the pics, notice the small inlet for my oil cooler. It?s only 2.5?X3.5? (8.75? surface)opening going into the oil cooler which has a core of 4?X5.375? (21.5? surface).
From the pics, you can see there is almost no where to go. From this location, I might could raise it up another ?? and go in another ?? while still maintaining about a ?? from top of cowl, and a ?? of an inch from the motor mount. Cutting out this more of an opening would expose me to 12? of surface area, which might not be that much of an improvement.
What have other 6 owners done here? I?m open to any suggestions, and it would be greatly appreciated. Is 160's even obtainable in this TX heat without it being too much work?
John
John
![34ef1cg.jpg](/proxy.php?image=http%3A%2F%2Fi47.tinypic.com%2F34ef1cg.jpg&hash=78d01eb8cee5c5511760c29cf67f9aad)
![29by2is.jpg](/proxy.php?image=http%3A%2F%2Fi48.tinypic.com%2F29by2is.jpg&hash=c62ab1a8aaa651c8202ea33640742fa7)
