Oil cooler fittings
AltonD
Question:
Should the two fittings on the engine, Oil cooler supply and return, be steel fittlings?
Van's calls out an aluminum fitting. -8D.
Many people do use AL. So far no one has reported a failure. I used steel. You can get steel from a hydraulic hose shop locally. I'm careful to not buy the ones that say "China" on them. I think some Parker fittings now say "China" some do not. I found some -8 Weatherhead steel that did not say "China" and that's what I have on the aircraft right now.
You will find people say "All fittings steel firewall forward". Usually some AL finds its way in there.
