The damper control arm is too thick for a B nut arrangement for the cable, and the included attachment method (bolt, nut and washers) didn't allow for movement, which resulted in a bent cable. Since the arm will move 90 degrees, it needs to be able to pivot, so I did this:
That's using Van's 'Bowden cable clamp' included in the FFWD kit.
==dave==
N102FM
![2mmb7k0.jpg](/proxy.php?image=http%3A%2F%2Fi59.tinypic.com%2F2mmb7k0.jpg&hash=28b03fb345d6a16801fb7f7de4d0d8f4)
==dave==
N102FM
