blueflyer
How many of you have ever had an oil cooler burst just after start up? I was about to go flying (not RV) the other day and the oil cooler gave up when I started the airplane. I saw the oil pressure was 3psi and waited 7-8 seconds for it to come up (it never came up) before I shut down. So, I got out and inspected. On the ground was a huge oil puddle. I bet I lost at least 50% of the oil that was in the airplane, so this was no little squirting leak. The hoses and connectors/fittings going to/from the cooler looked good from initial inspection. There is no discernable distortion of the oil cooler, but alot of oil was just dripping out of it when I looked (after shut down).
I havent removed the cooler (or cowling) for closer inspection yet, but I cant imagine why that would happen other than just a defective cooler. The cooler has about 150 hours on it, on an 0-290 engine that flies regularly. Its a 7 row Aero-Classic that is less than 2 years old.
Now, I dont know if this would make the cooler burst, but the oil screen had been inspected and reinstalled prior to this incident. Also, the oil sump has a coarse screen which had been taken out and reinstalled for inspection as well. Oil was changed and filled to normal ops level. One theory I have come up with is that somehow the oil screen gasket may have gotten pinched somehow during reinstallation and I didnt realize it??
Anyone have any ideas why this may have happened other than defective unit?
