I've experienced numerous delays in my 12iS build, some of which are even my fault.
. I have the engine hung and plumbed and am wondering the best way to periodically circulate the oil. I can easily jump the starter with an external 12V battery and would 'burp' the oil system first. My questions are:
1. Is it better to do so with the spark plugs in or out? I would think relieving the compression would allow the Rotax to build oil pressure easier and faster. However, I am unsure if the lack of compression returning oil to the tank is a problem.
2. Would you use an engine fogging oil sprayed into the cylinders before spinning the engine?
Thanks in advanced for any responses.
