Where most guys seem focused on speed, I love playing around with keeping my engine nice and cool.
I was considering adding a NACA inlet to the rear side of the lower cowling and running scat tube to my engine mounted stewart warner oil cooler with a cable actuated throttle in the tube.
This does two things: Provides cool air directly to the oil cooler and allows all the air in the cooling plenum to be used for keep the cyl cool.
NACA vents work by creating counter rotating vortexs due to the sharp edge that then entrain the air within the boundary layer - which is low velocity and therefore low drag. I'd run some tube at the oil cooler outlet to the cowl exit as well to prevent over pressurizing the low cowl volume.
Know of anyone who has tried this? I called VANs to discuss it and received the response I expect, "why would you change a design that already works well?" hahaha my answer, "cause I can".![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
