Hi, getting ready for the 25 hour inspection. Do most of you burp the engine before draining the oil and also do you fill the filter before adding oil back into the engine after draining the used oil. Do we also do the procedure for the first engine run to make sure the lifters are pumped up, just wondering how everyone else does it, 25 hours of flying with no issues. Don Lewis, Jackson Ohio
