okay,, installing the right console.... I temporarily installed the f804, looked at it hard and realized after fitting the console that it was upside down (short bent bent end goes towards floor) (nice instructions btw). Put it right side up, installed the console, drilled and installed the nutplates. started drilling the holes on the f804 to cleco the piece to the fuse (later pop rivets for install). Drilled the first hole, taking a long time?.... I'm drilling into the spar!!...why... the 804 has not been pushed up to clear the spar.
So....I have a partially drilled hole in my right spar near the top.. depth about 1/8 of an inch....do I have to replace the spar? is there something I should do.... am I panicking for nothing?
