dave4754
I post this for other users, my mistake that is.
While screwing in the screws in the rear of the canopy i was using my battery powered screwdriver and when it came tight i let go. All screws went in well until the ONE!
Located on the upper right hand corner where my plexiglass did not come into full contact the screw pulled down too far and TOO quick for me to feel it.
The crack was small around the screw and i have stopped drilled it and will apply some resin while doing the front Resin work but it is there and i can see it and yes it Hurt!
Just wanted to pass this along and suggest that my experience should tell one not to use powered screwdrivers on the plexi install as you would feel that tension before the crack happens..... Anybody have a towel I feel a cry coming on.
