Odyssey PC680
FrankK90989
Folks,
Any one from cold country have any comments on this battery? (Odyssey PC680)
I see some car people have not had very good luck with this battery when it gets cold.
Frank k.
N. Mn
9A
90989 stickin things on the firewall, getting cold up here!
I've had one of these in my 6A for 3 years now up in Canada, no problems but I keep the aircraft hangared at about 50F most of the time. I have a Subaru engine running 15W50 Mobil 1 oil and a Denso starter. I'm using another one in my RV10 under construction now. 10 lbs. lighter than a conventional battery and it seems to work the same so far.
I have the PC625 in my -8 with an IO-360-A3B6D, and I have never had any problems starting with it. And it gets COLD here in Ottawa, Ontario ;-) Anytime the temperatures are going to be below freezing, I plug the sump heater in. But I have had no problem starting when the outside temps are -15C (5F).
Cheers
I have that battery in my 7A with an 0-360. I hangar, but unheated. Never had any problems and the battery is going on two years. Seems to be a Great battery and nice and small and light. And no venting required.
Roberta
