dan said:
Playing devil's advocate here... Plane sits out in the sun for an hour on a hot summer day. The "greenhouse" effect under the emp fairing will cause your OAT to read higher than the actual air temp. How long after takeoff will it equalize with actual OAT?
After all, it's not IAT (inside air temp) or OHAT (outside heated air temp), it's OAT!
I just knew I was going to hear about this when I made that post.
A little justification is in order.
1. I have exchanged emails with a few others who have placed it there, it seems to work for them.
2. My -9 will be a VFR ship and I don't really care about TAS
3. The Dynon OAT plugs into the remote compass, which is back in the tail so running the wire out to the wing would be a PITA.
4. This will be a tail dragger and my fear is that putting it under the HS might subject it to some damage.
5. It will be easy enough to move later as I left enough wire to do so, if needed.
6. I checked with Dynon, they thought it might work out fine there.
There are a lot of down sides to this installation, as pointed out. I figure it will read high when I first get in the plane but after some air starts moving through that area, it should cool right down. Once it is flying, I will come back and let you know how it works.
