Fix the problem without moving the probe
This problem is caused by the fact that most OAT probes (sensors) are metallic (often brass) and the main body is bigger than the small little probe it self. If you mount it in a NACA vent so that the body part of the probe is in the cockpit area, the conduction that takes place with the probe body causes temp. errors (the body has much more thermal mass than the little probe tip). The errors can be quite large in low temp conditions when cabin heat is being used.
One way many builders have fixed the problem is using some of the low expansion urethane foam in a can, to insulate the sensor.
Use a small Dixy type drinking cup to make a form for the foam, and then inject the cup with just enough foam to fill it.
The only down side is that it makes replacing a bad sensor a little tougher, but it is pretty rare for them to fail.
The best thing is to not put them there in the first place (spred the word),
