Paul Eckenroth
I'm looking for some input from the Lycoming gurus out there. I have an RV9A with about16 years and 1300 hours. Up until last year it would start instantly in the summer with no primer used and instantly in the winter with 4 seconds of primer. Last year it started requiring 2 seconds primer in the summer. Winter operation remained the same as previous. I figure that the change in primer required for summer operation indicates that a component is deteriorating. Once it starts in the summer it behaves normally with proper power and speeds. Plus fuel flow remains consistent.
I would appreciate advise on what I should check and what the likely culprit might be.
Thanks in advance.
Paul
Thanks in advance.
Paul
