My current wing has an aluminum pitot line and I intend on using nylon in fuselage. I feel that Nylon in the wing, transitioning to a simple 90* nylon fitting at the fuse is the most elegant method. However, I was worried Van's did aluminum in the wing for a reason and saw several folks leave the alum line in the wing.
Am I ok with nylon tubing in the wing?
Larry
Larry
