Wondering how everyone dimpled the nutplates on the inboard wing, Section 16, Top Wing Skins(New Numbering, I think the old was 14). Did you dimple through all three pieces together, the top skin, the doubler and the rib, or separate out the parts and just dimple the top skin for the #8 screw. If so, how did you address the wing walk doubler? I had someone suggest to separate them, then drill an oversize hole for the dimple to sit in, in both the wing walk and the rib. Suggestions? Also, what did y'all use as .032 skin or scrap to test the fit of the mating of the two top skins? Thank you for any help you can give.
