rv9aviator
I just noticed I have a problem with the lower nut plate on the fuel pump doubler which is touching the lower motor mount and holding it off the firewall by about a 16th. I won't be able to tighten the two lower motor mount bolts that are left and right of the nose wheel mount without binding. Has anyone else had this problem, and what was your fix.
