Previous poster has it right, but just for future reference;
in the absence of other info, the industry standard default is a minimum of 1 washer under the nut, but if the nut is bottoming out on the bolt shank before it gets tight, you can go up to a maximum of 3 washers to take up the extra space. Any more than that and you change to a shorter bolt.
