I've got a small leak that's coating my windshield over about 1.5 hours of flight. I have determined it's engine oil, as it was clear right after an oil change, then got darker as I put more time on it.
It crept up as I was breaking in 4 new cylinders, running hard and varying RPMs. I can't seem to find the root cause though. It is coming from somewhere far forward, as it's all over the front lip of my cowl, right behind the spinner.
We installed this new WW 300RV prop in Jan, and since have put about 70 hours on it. I just noticed this very annoying leak in the last 8 hours.
What's baffling me is everything up there is dry.
Crank nose seal - dry
Back of spinner - dry
Prop blades - dry
Ring gear - dry
Rear of prop hub - dry
Front cowl vertical surface - wet
Case top mating surface - leaking since I got the plane (200 hrs)
Oil pan gasket - leaking since I got the plane (200 hrs)
Possible small leak at the base of #1 cylinder (there was a nick here in the case we noticed during cylinder install)
Pulling the spinner tonight to inspect the hub.
-Don't judge my sloppy RTV job, it was a rush job to get the plane in the air the next morning!
-The #2 fuel line leak has been fixed.
Prop blades - dry
Ring gear - dry
