GAHco
This is probably common to most models so chime in.
I am wiring the left wing of my 6, I have electric aileron trim and I am running the 5 wire Ray Allen cable through the wing and then out.
Th question is where do you put the hole in the rear spar?
It seams to me that it needs to be just outboard of the inboard aileron bracket, but high, or low, I dint know.
It will need some kind of slack to allow comfortable full travel of the left aileron without causing interference.
If you have done this or seen it done and work well over a period of time, let me know.
I saw nothing in Vans supplement that came with the kit.
I would appreciate your kindly assistance, measurements, photos, etc.
Thanks, Tom
Thanks, Tom
