Flying C
Member
I've started riveting the HS and want to be sure I don't get too far ahead of myself. There is a note on the drawing that says "Matchdrill Under-Structure using Skin as a Drill Guide". According to the instructions I am suppose to rivet these holes, with the exception of the 10 that are used to which it states "Leave Open on Top Side Only....." So, my question is what is ment by the Matchdrill note? Should I rivet these holes or should I wait until later? Thanks again for your help.
Jake
Jake
