Scott Will
The past week I had reason to remove the gear leg fairings to gain access to the hydraulic brake lines. When installing the main gear leg fairings for what I thought was the last time, I used the Great Stuff expanding foam from the aviation aisle at the Depot.
Here to say that I wish I didn't do that. Why? Well it makes for removing the gear leg fairing a huge ordeal that almost resorted to me cutting the fairing off. I could not pull the hinge pin out at all!! I ended up using a pair of small vice grips and banging on it with a hammer... til the end of the hinge pin fell off! I was able to dremel away a small amount and get a fresh piece of hinge pin and use the vice grips with moderate success. I destroyed the hinge pin getting it out.
When the foam cures, it leaves behind a very tough glue ... I originally thought, "hey, I'd just throw some acetone in there and eat the foam away". Boy was I wrong. The glue managed to get in the hinge pin... ughhh.
After I managed to get the fairing off, I spent a while cleaning up the gear leg and inside of the fairing. Acetone would eat the foam but nothing I found cleaned off the glue. Now my gear leg fairings are showing the rivets popping thru the paint after working the fairings quite a bit.
Turns out I have to do the other side as well. Not looking forward to it. The good news is the new hinge pin went in a lot easier than the other came out. Now tomorrow I have to do the other side and hope I don't destroy the hinge pin.
Would I put foam in the fairings again? Not.
